New turbo
I have just fitted my new Turbo , oil feed, sump pick up, and pcv  on the rocker cover, so far no leaks and the smoke and uneven revs are gone, but should I need to check anything else as mileage seem a little bit down judginging by the Ave mileage display, I know this is not accurate, but it still isn't reading what it did before I changed the Turbo
Many thanks
If you have Forscan, you could check to see if there's a turbo actuator adaption reset available.  The actuator might be physically set slightly differently to your old one.
The MAF may also be getting weak on a car of this age.  Though not worth the cost of a new one just to save a couple of MPG.
I have forscan but that is above me...got mot soon will ask my garage to check settings as he done my ECU this year
Crikey, you fitted a new turbo yourself, which is impressive! Surprised a bit of forscan has you stumped lol
Had help from son with Turbo, he may be able to work it out lol...I can use a spanner changed engines gearboxes head gaskets in my younger days  but modern stuff is another story...
