Part numbers! Help explaining them?
I need to change my speedo, I have found a replacement online but the last 3 digits on the end of the part number are different.
Could someone explain the difference and if it will work in my car?
I'd do a Google search to ask the differences between the two numbers.
Is the speedo unit you're looking at from the same car as yours. That is same age and spec?
Hi Ricky, can I ask why you need to change the 'Instrument Cluster' ???
The car's BCM and other modules are likely to have communication issues with any replacement unless it is reprogrammed with FORScan as the VIN numbers will be wrong. Also used replacement must have the mileage less than your original instrument cluster because the mileage can only be adjusted upwards (you can not reduce the mileage).
I messed up my milage I've got xxxx on my mileage and I was going to swap the cluster. Is it not as simple as swapping them?
No !!
If you know which module you were playing with, for example BCM, then you can reload the 'AsBuilt' files direct from the Ford server. Your car still knows the true mileage even if it is not displaying it. At least 3 or modules store the mileage data to help prevent fraud and attempts to roll back mileage. Resetting the module that has the corrupted information with the original software settings form Ford will in most cases resolve the problem.
Can I do this with forscan or can only ford do this, I want the cars correct millage on my dash.
Yes you can use FORScan, windows laptop version (with licence) and a vLinker FS lead to download the AsBuilt file from the Ford servers. Depending on what you did to cause the mileage display to become corrupted you may need to reload the AsBuilt files to more then one module.
My knowledge is that only last letter is not important. This last letter is going up with the time, sometimes it reflects to years passed from the time this part was manufactured first time - letter is A. Sometimes reflects some changes like different manufacturer, materials etc. Generally - does not break compatibility.
Other letters are important and is better do not swap for ones which do not match unless you know exactly what are differences and consequences.
Provide VIN, I'll check in microcat what is your designed IPC however it rather should be like your original one.
The "10849" part number is the correct number to search for for the assembly and those two numbers do not match.
You must source a BBK or BBL, BBM, BBN etc
UNLESS someone tells you for definite that a different part number is compatible
But if you take your car to a main dealer, they will fix your cluster issue (for a fee, obviously)
So I have more of an understanding on the part numbers the last 3 digits are versions so if I was to replace I am best getting the same.
I have forscan and a vLinker FS and I have downloaded the asbuilt file from motorcraft. This is where I need a little help.
I've see on youtube someone upload asbuilt files to his IPC and SSCM but he used 2 different files. The file I downloaded was just 1 file,is that a generic file for all asbuilt?
Yes. This tool will show what is inside:
https://www.compulsivecode.com/Project_AsBuiltCompare.aspx
i cannot make heads nor tails of it, i loaded the as built data i downloaded off motorcraft and its showing me all letters and numbers that doesn't make any sense to me. it shows me what's on the motorcraft website.image.thumb.png.60325dc5963a61b758ddb58656c258bb.png
Ekm. There is nothing else. Just numbers. You can search google for interpretation. There are number of posts, spreadsheets etc. which decodes these numbers. Each module has address prefix. e.g. IPC is 720. So, data for IPC are all with address 720-xx-xx
701 GPSM      Global Positioning System
706 IPMA      Image Processing  A
712 SCMG      Seat Control  G
713 SCMH      Seat Control  H
714 HSWM      Heated Steering Wheel
716 GWM       Gateway
720 IPC       Instrument Panel Control
721 VDM       Vehicle Dynamics
724 SCCM      Steering Column Control
726 BdyCM     Body Control  / Generic Electronic
727 ACM       Audio Control
730 PSCM      Power Steering Control
731 RFA       Remote Function Actuator
733 HVAC      Heating Ventilation Air Conditioning
734 HCM       Headlamp Control
736 PAM       Parking Aid
737 RCM       Restraint Control
740 DDM       Drivers Door
741 PDM       Passengers Door Control Unit
744 DSM       Driver's Seat
746 DCDC      DC to DC Converter Control
751 RTM       Remote Transceiver
755 VSM       Vehicle Security
757 TBC       Trailer Brake Control
760 ABS       Anti-Lock Brake / Traction Control
761 TCCM      Transfer Case Control
764 CCM       Cruise Control
765 OCS       Occupant Classification System
766 PRB       Power Running Board
771 RETM      Rear Seat Entertainment
772 SRM       Speech Recognition
774 RCU       Audio Rear Control Unit
775 LTM       Liftgate / Trunk
776 DCSM      Driver/Dual Climate-Control Seat
777 PCSM2     Passenger Climate-Control Seat  2 rear
782 SDARS     Satellite Digital Audio Receiver System
783 DSP       (Audio) Digital Signal Processing
785 RHVAC     Rear Heating Ventilation Air Conditioning
791 TRM       Trailer
797 SASM      Steering Angle Sensor
7A5 FCDIM     Front Control/Display Interface
7A6 FDIM      Front Display Interface
7A7 FCIM      Front Controls Interface
7B1 IPMB      Image Processing  B
7B2 HUD       Head Up Display
7B5 ILCM      Interior Lighting Control
7B7 BCMB      Body Control  B
7C3 HCM2      Headlamp Control  2
7C4 SODL      Side Obstacle Detection Control  – Left
7C5 SECM      Steering Effort Control
7C6 SODR      Side Obstacle Detection Control  – Right
7D0 APIM      Accessory Protocol Interface
7D5 DACMC     Digital Audio Control
7E0 PCM       Powertrain Control
7E1 TCM       Transmission Control
7E2 CDIM      Circuit Deactivation Ignition
7E3 AHCM      Auxiliary Heater Control
7E5 AFCM      Alternative Fuel Control
7E5 OBD_FICM  Fuel Injection Control
7E6 FICM      Fuel Injection Control
7E7 ACCM      Air Conditioning Control
7E7 BECM      Battery Energy Control
