Electric windows
 Will these regulators fit my focus mk1 2004. with it pointing out its a multie pin not a 2 pin i thought  id better check as i dont no wich i need... it dose not say auto on the window button... im told it makes a difference 😆https://www.ebay.co.uk/itm/324388393534?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=apGN8aAWRAS&sssrc=4429486&ssuid=bDzm6g9WSjy&var=&widget_ver=artemis&media=FB_MSG
Should do, as long as it's a 4/5 door.  The 3 door regulators are different.
This is for basic electric function.  The multi pins are for one touch open & closing as well as 'global' function.
So it is a 5 door only my front 2 electric driver side has left and rite  window and passenter has only left
Yes, that should be the right one then.
So the  regulator  i got was the wrong one  and now i need a motor and reg for both doors ..i rang my local scrapy who very kindly gave me these . Looks like the whole pannel left and rite are these gonna fit not what i was expecting .
Those are for a Mk2 Focus.  Are you sure yours is Mk1?
They won't fit then.
Why wouldn't the first regulator fit?  That's the correct one for your car.
If it would fit but you need one with a motor as well, it should be this one.
https://www.ebay.co.uk/itm/131708118888?
**EDIT** - Just checked the link in your original post.  That's a multi-pin type.  You need the two pin type.  The link in this post is correct.
Mechanic said it didnt fit with the motor .i need it to moro  so looking  at this but dont no if i need comfort function or not or if it matters either way .https://www.gsfcarparts.com/wpswpr3508rm
Or
https://www.eurocarparts.com/p/window-regulator-492590341
Regmatch says they both fit but 1 is comfort and one isnt
15 hours ago, dieselblue said:
Yes old shape
I love the simple lines of a nice Mk1, it really was an excellent bit of car design...
Or
Comfort function is multipin (auto up & down plus global opening) so I'd say that's NOT the correct one if you don't have auto on the switch.
The regulators are also different each side if you're not aware.  You'll need one right and one left if both need replacing.
