Coolant Bottle air bubbles
Hello
Coolant bottle cap was glued on and I managed to change it and since I did that change I was keeping closer look at coolant bottle and I have noticed this issue you can see on the video in the link provided. I have changed the bottle since but problem seems to be still there. Idk if this bubbling is a problem or not but car drives fine and no overheating problems but I am not sure if this bubbling is normal or not. Coolant level seems to stay in the same place. Any help, suggestion or solution welcome. Thank Yoy guys
https://drive.google.com/file/d/1wgKhHCHkavHcF6U--eP3XQQYr1davKOj/view?usp=drivesdk
I’ve not personally noticed that before, but it’s certainly bubbling.
Could be a number of things, super hot water from around the turbo, not sure if these cars have a auxiliary coolant pump that runs after the engine shuts down.
Did you buy a genuine Ford coolant cap and expansion tank?
