Mk 2.5 Fuel trims-uneven idle
I have a 2.0 Duratec with a slight drop in rpm at idle. When connected to Forscan it shows that when it stumbles, the LTFT rises to about +18 and STFT is jumping betwen -3 to +18. The LTFT is also jumping around. Raising the RPM to about 1500 steadies the LTFT to around +7. I am not sure if these fuel trim numbers are out because the battery has been disconnected and new values have not been learned. However, it is acting like an air leak.
Anyway, a smoke test showed that the EGR was leaking from a weep hole in the casting. I am not sure if this is the source of an air leak as i do not have another car to test.
A vacuum test also showed a fluctuating reading of about 1" Hg.
The Map sensor has been tested against barometic pressure and is reading correctly.
