Ford Focus 2019 - Electronic Parking Brake Fault
I currently own a 2019 Focus, and I have a Handbrake malfunction error warning. The error is intermittent, some days it comes up and then it goes away. There is plenty of fluid in the reservoir. The handbrake is still engaging, at least I’m pretty sure it is. You can hear it. Any tips on what the issue might be?
Cheers.
Dom.
Have you used FORScan to check for any DTC's ?
You say it seems to be working, but is it working on both sides ?
Possible seized  handbrake mechanism on the caliper.
Brake fluid has nothing to do with handbrake.
If discs are heavily worn AND the pads it can also cause the piston to bottom out and cause a fault
