1.4 TDCi fuel filter connectors
Hi, I am new to the 1.4 TDCi engine and diesels in general. Please could someone help me identify the 3 pipes that connect to the fuel filter. I think they are called "inlet" (coming from the fuel tank), "outlet" (going into the high pressure fuel pump) and "return" (leak-off from injectors). Thank you in advance for educating me.
3 pipes?  I think there are only 2 pipes actually connected to the filter housing.
The pipe that comes from the centre on top is the outlet (towards HP pump).  The pipe at the side is the inlet (from fuel tank).
I should have numbered the connectors in the picture... I think what you are saying is this:
  • Connector 1 ("inlet") comes from the fuel tank
  • Connector 2 ("outlet") goes to the high pressure pump
  • Connector 3 ("leak-off") does not actually connect to the housing of the filter, but goes somewhere else (fuel tank?)
Is my understanding correct?
17 minutes ago, mbrijun said:
  • Is my understanding correct?
Yes, that's correct.
