Mk2 IB5 Gearbox oil level
The Mk2 Focus Haynes manual says this gearbox should be filled to the bottom of the filler plug threads. Other gearboxes I have seen in the past are also supposed to be filled to this level.
I have read some posts on here that suggest it should be around 10mm below the filler plug hole. I have never heard of this on any other gearbox.
What was Ford's reason for that?
Tbh when I filled mines it was very awkward so I filled it until it fell out and waited on it stopping dripping but you will need something under there to soak it up I cut off a piece of water hose and from the top of the engine I moved it down to the location and pushed it in then the oil I had plugged into the the hose and I filled it that way downward.
Fill to the dribble
Thanks for the replies.
I had already topped it up to the lower of the filler hole.
It took around 100ml of oil to bring it back up to level.
There is a small leak from what appears to be the mainshaft seal inside the bellhousing.
I cleaned the area behind the plastic cover out with brake cleaner last time I checked the oil level. It was still completely dry this time.
The oil seems to be leaking from the bellhousing to gearbox joint.
I was typing on a phone when I posted the last reply.
The bottom of the gearbox always has a coating of oil, but it isn't pouring out.
I asked them to check the oil level while the car was on the lift at my last MOT in February this year.
I saw with my own eyes that the level was ok then.
I also checked it myself when I bought the car in Summer 2021. It was a bit over-filled then as quite a bit poured out.
I have an invoice that the clutch was changed in Feb 2019, so I assume that the box would have been refilled with new oil then.
If I have the car long enough that it needs another clutch, I will have the seal done while the box is out.
