Ford transit lights flashing every 10 seconds
My 2019 transit h3 l4 headlights are flashing every ten seconds when left locked, does anyone know what it could be, I have to unplug main battery under the seat overnight!
Probably water ingress into the body control module. That's where I would check first. You will need a mirror on a stick ideally to look at the pins on the bcm for corrosion unless you take the dash apart to access the bcm. But You may see water or corrosion on the connectors you can see with a torch when you unclip each connector.
