2012 2 ltr diesel focus , fuel filter
Hi ,
Does anyone know if you have a torque setting for the torx screws when refitting the fuel filter housing cap.
Mechanic changed my fuel filter and I have some air bubbles post filter housing .
thanks .
Just "FT" but not "VFT" or you could break it.
Hi ,
thanks .
Probably got the seal trapped . Remove the top and check. Those screws just need pinching up normally.
Official torque is 10 nm.
Thank you for the replies.
I will check at 10nm , will probably change the filter again but use a genuine ford one , and check the current seal for damage when I change the filter .
Thanks again.
