Ford Fiesta Radio/Sync issues
Hi
this is generally my last resort before I take my car down a dealers and have them make me pay a small mortgage to get it looked at and sorted but recently the past month or so I've been having on and off issues with my SYNC slowly starting to play up and just instantly disconnecting any device that tried to connect/play music through so I decided to look around online and found some solutions I decided to do a whole reset on my SYNC and after that it completely had stopped work , looked a bit more into this and seen that a possible fuse (fuse10 SYNC fuse) I have replaced this fuse and for a small glimmer of hope it worked for a second but at a restricted amount so I decide to reset it once again and now I'm back to square one again. nothing works now I can only changed the time and that is it now. I've tried to take the fuse out again and replace but its still no success. I was wondering if anyone else had a better fix or even a permanent fix for this cause driving to and from work with no radio nor even my own music is unbearable
Disconnect battery negative for 10 minutes and see if it comes back
Tried this multiple times nothing changes at all
Before you put it into Ford and spend loads of money, get FORScan and connect and see if the module shows up, it could also be a Radio (ACM) fault.
If it doesn't just source and fit a replacement module
bump
Got a scanner over the weekend and nothing has displayed on it at all done it multiple times and zero errors so not sure what the next step is
Buy second hand units or head unit if it's combined
