'12 Mk3 intermittent no start
Hi all,
A Focus Mk3 2012 1.6 Petrol was brought in with a no crank no start. I scanned the car for codes and found a few Lost Comms codes and 2-3 P codes. Upon clearing fault memory the car fired right up and lasted a few days then the same thing happened. I cleared the code and started fine.
One code that is persistent U0131:00-2F - Lost Comms with Power Steering Control Module 'A
Hooked up FORScan and PSCM is not listed as a module (no comms) and BCM stores this.
===BCMii DTC U0131:00-2F===
Code: U0131 - Lost Communication With Power Steering Control Module 'A'
Status (-2F):
 - DTC Present at Time of Request
 - Malfunction Indicator Lamp is Off for this DTC
Module: Body Control Module
 Freeze Frame  #1:
-EVENT_TIME: 356742186 s (Tue Oct 10 12:52:40 2023) - Event time
-TOTAL_DISTANCE: 61415 km - Total Distance
-MODULE_VOLTAGE: 11.8 V - Control Module Voltage
-INCAR_TEMPERATURE: 126 °C - In car temperature
===END BCMii DTC U0131:00-2F===
I am trying to be carful not to look down the wrong path and waste alot of time, so my guesses are.
1. PSCM Module fault ( could be interfering with CAN )
2. CAN Issue somewhere else (Maybe engine bay fuse box connector - connects CAN to ECU then TCM)
3. Issue with Alternator / Grillie Actuator ( Thats on ICAN though ?? )
4. Bad Grounds?
Thought, Suggestions ?
Early MK3s had issues with water ingress into the BCM from the washer jets/hoses.
Check for water damage
