Fiesta 1.3 (2002) High Idle problem
I have a strange problem with my Fiesta that i can't resolve. When I start the cold engine everything is normal, idle is at about 1300 rpm at start and slowly decreasing down to 750 as the engine gets warmer. But soon after engine temperature reaches 70 C rpm are starting to rise again so that at 90 C it works on about 1200 rpm. I have checked all vacuum tubes for leaks, checked ECT sensor, checked T-MAP sensor, checked TPS sensor, changed ICV valve, changed air intake seals and nothing helped. One more interesting fact is that when engine is hot and it reach the point when idle is too high you can turn the engine off and after you start it again everything is normal. Like turning the engine off resets the problem, but after driving it for some time the problems is back again. Anyone have any other ideas, what more can i try to do to resolve this problem ?
