MK2 gearbox oil
I am bout to replace the clutch soon and also the gearbox oil as i will need to drain the box(1.6 tdci with MTX-75 box). Would any 75w90 oil do which is GL-4? That's what i have found out the box uses, but do correct me if i am wrong. I am looking for a Castrol oil that will do the job, but I don't need the most expensive of them.
Thansk in advance.
1 hour ago, TomsFocus said:
Doesn't seem to work for me... 🤔
Doesn't work for me either, and it certainly won't work for Lars with his Norwegian registration 🤣
Just now, andypsp said:
Hope you selected country 1st before putting your reg in 😉
I did.  And tried 5 different reg numbers.
Are you saying it does work with your reg? :unsure:
Was working fine on my laptop yesterday when i did a search 🤪
Well, it still isn't working on my laptop lol.  Hopefully they'll fix it tomorrow...
  • 4 weeks later...
Thanks guys! It worked here with my registration plate, but it was only for the engine oil, no recommendation for the gear oil. Anyway, i have got what I wanted now after reading a lot on the world wide web😋
