Retrofit Parking Aid on a 2022 Transit V363e Chassis
unfortunately the chassis comes without parking aid. I thought it is easy to retrofit, as many moduls are available. But this was 6 weeks ago and I have not made any progress.
I do have the schematics of the car and made my own wiring. The modul connects on HC1, which seems to be different to older cars where it connetced to MC1.
Only this Modul is recogniced from the car and Forescan:
PAM - Modul
P/N: KU5T-15K866-AE
Calibration level: KU5T-15K866-AE
Strategie: KU5T-14C090-AE
However I do get errors and even if I clear them, they come back. The PAM is not detecting any Sensor. I have manually checked that the wiring is correct and have even sourced different Sensors. But the result is always the same.
I enabled the function in IPC and PCM and configured the PAM.
It seems to me that the code the BCMII is sending to the PAM doesn't match and doesn't enable the modul. Or it might be broken.
KU5T could be just wrong.
Is anyone able to [b]share the correct code of the PAM[/b] for this car model.
Motor: Duratorq Turbo Diesel Common Rail Injection
 2.0L /  7/2022
Generation: 2019.75MY
Many thanks for any advice
