What to check next
My 55 plate 2.0 diesel Transit wouldn't start one morning , This wire had burnt out, I've rejoined them cleared all fault codes, the relay now clicks on ignition, still won't start, and have the  fault codes in the pic, what should I check next?
Next step is accessing the fuel pump module (attached to pump) to check voltage at the plug.
Thankyou will try that tomorrow, is it on the fuel tank or side of engine ?
Side of the engine, underneath the intake manifold.  You may need to remove some parts for access.
Edit - Just noticed 2015 in your profile.  Is that a typo or was the '55 in the OP a typo?
It is a 55 plate. Thanks.
It would be helpful if you could update your profile to show 2005 👍
  • 4 weeks later...
O yer , thanks . Adjusted.
