Radio Fuse MK 2.5 Ford Focus
Hi
Went to fit an Xtrons andriod radio this afternoon, I thought it would be a simple plug and play. I have fitted similar to others cars so the lack of instructions did not worry me.
All fitted but it did not work, tried the fuse in the back of the radio but that was fine. As the light was going, I thought I would put the old one back until tomorrow and then see if the unit was faulty, even though it is new.
Put the old radio back and that is no longer working, so I assume I have bown a fuse, never happened when fitting a radio before, so a bit annoying.
Could somebody confirm which fuse is for the radio, I did look online but my searches for some reason were more American.
The location of the fusebox does not help and I understand there could be more than one fuse.
Martin
F108 & F112
F108 & F112
Brilliant, thank you, will have a look in the morning. Hope it's a simple fuse issue rather than the new radio not working. I was hoping it would be a simply plug and play, I hope after this it is
17 hours ago, TomsFocus said:
F108 & F112
Thanks again, it was fuse 112, replaced and the radio works, and the new one works perfectly, thank you
Martin
