MK4 Battery Removal
Wow - it's completely buried under the windscreen
I can't figure out how to get the air filter lower box out. It has 2 weird clips/nuts holding it in place from the underside.
Anyone have any advice on removing the lower box please ?
Cheers.
It's just pegs into rubber grommets. Just at give the housing a strong pull upwards. If tight, just spray a bit of wd40 or similar on that area.
Thanks so much 🙂
Very Appreciated.
This might help - it's for an S-Max and very helpful when I changed my battery recently.
It took me about 1-hour going slowly and I bought new cable ties to refit the cables from Aliexpress!
And
Spot on. Thank you. No need to post the pics I took, now 🙂
