Power steering not turning on
Hi all got a mk2 focus 1.6 2.0 converted
So after sorting out some previous issues I have now found a new one
Power steering pump doesn't turn on but when I go and put a heavy wire from batter to power steering pump connector it works fine any help
Someone will slap me down but I think you need HPAS for a 2.0 not EPAS.
You may have to consider changing the rack
Changed it same thing
EHPAS is controlled by the PCM as it's speed variable and uses a huge amount of power that the alternator output has to adapt for.  The 2.0 PCM may not be set up for it.
Can you access the EHPAS module in Forscan?
Can you see any tickboxes in the PCM for PAS type?  May need ELMConfig for that on a Mk2, not sure if Forscan covers that sort of thing now.
I thought that is well but I'm not getting any sort of power thru the connectors that go into the pump checked all fuses they're all ok
Changed it back to HPAS?
Problem solved the pump got siezed so replaced it with a st225 all working fine now
