heater blower replacement
Hi,  I have a ford focus 2009 estate is there any easy way to take the heater blower out I have stripped both side under the dashboard off and its so tight to get your arm up there to twist and push it out to the passenger side .I was going to strip the clutch pedal box out next any advice would be appreciated thanks
  • 1 month later...
Update date on  fitting a new heaterblower .what a pig of a job lol you have to strip both side under the dash board out  and take the clutch pedal box and clutch slave cylinder out too it the only way to get your arm up there to twist and push out to glovebox side plus when it all go back in you will have to reblead the clutch pedal so it would be a job for a mechanic unless you have been messing around with cars a lot .
