Focus mk3 2011 I changed to one with Sync 1.1 from Focus mk3
I replaced Novero to Sync 1.1 with FCDIM, ACM, APIM from Focus mk3 FL. While I dealt with almost everything because the pins and wire colors did not match the schematic, everything works BT audio, USB, Radio, etc. It's the problem I have that when I turn on the power(START/STOP) the sound from the APIM(bt,usb) module goes off --> ACM doesn't play sounds in the speakers. It seems to me that
everything is changed as it should be in CCC.
-Please tell me what pins or wire colors (BT/VC) are from the microphone on the Novero?
-I also have a problem changing the settings for ACM, APIM or FCDIM on UCDS(made in China). For example, in other modules, there was no problem and here when trying to save, I get a message that "Direct data not found or incorrect(corrupt), need to read it from vehicle or open file!"
I also updated Sync and the language changed to my native language.
I connected according to what I had drawn, as for the pins described ACM was already directly in the harness and plugged into the ACM. Is something missing here?
I still have Forscan I can change AsBuilt but what are the settings for Ford Focus mk3 With rear sensors (PDC) for APIM AND FCDIM? Unfortunately, it does not see AsBuilt for ACM.
