M7.5 eco boost clutch sometimes not dissengaging
Sometimes I’ll have my clutch pressed all the way in but if I let off the brake the car will move forward even with the clutch pedal fully pressed anyone had this. My drive starts off normal with a normal biting point then the biting point starts to lower getting closer to being fully pressed down
Yes, it's called clutch drag.
Unfortunately it's not so easy to diagnose.  Can be the master cylinder, slave cylinder, or even the clutch itself.
I'd assume a seal failing in the master cylinder letting the fluid slowly bypass back into the Res and reducing clutch fluid pressure
