My fix or repair daily
So my 2016 1.5 tdci is at it again ,abs, traction control, hill assist,airbag and eml lights are on replaced battery after the first time next step is alternator but can't keep throwing money at it had anybody had this issue that could help be well appreciated. Check codes abs module and wheel speed sensor
I assume you have another thread(s) somewhere on the forum under a different user name? 🤔
Replacing the alternator is unlikely to fix the problem unless it is genuinely faulty. If the battery is less than two years old then the car is probably suffering like many other modern cars and just needs the battery charged about every 5 weeks unless you are using it every day and doing at least 20 miles.
I use the car a lot to go to n from work its a good 30 miles a day and put new battery in few days ago was doing okay then the issues also had same problem wi old battery in
Use a multimeter and measure the battery terminal voltage one hour after it is parked to see what the SOC is.
