2 year service Focus st line auto
Hello,
Could anyone kindly advise what's included in a 2 year service i.e what items are checked / changed. The reason being I don't want to pay the prices Fords are charging and I should like to get the 2 year service done at a garage that will issue an invoice saying genuine Ford parts used.
I also looked at the garages in the good garages link , provided. I saw one or two that I liked but as is always the case I saw good and bad reviews and that concerned me.
If I have posted in the wrong area, I apologise
1.0 EcoBoost Auto (non-MHEV)
Replacement items: Odour filter (aka pollen filter), engine oil, engine oil filter.
Optional item: Brake fluid change.
Service Schedule
Model Focus 2019
Variant 1.0L ECOBOOST/AUTO (01/05/2018 - )
Interval 2 Years (18000 ml)
Repair/Order No
Reg. No.
Reg. Date
Radio Code
Mileage ml
Check for any outstanding service actions by using OASIS and ensure they are completed
L - Labour item - invoice at additional cost
Driving Vehicle into Workshop
Instrument gauges, warning control lights and horn Check operation
Windscreen, washers, wipers Check operation and condition, if necessary adjust/repair/renew (separate repair order required)
Inside Vehicle
Exterior and respective control lights; instrument cluster illumination Check operation/condition
Parking brake Check operation/adjust, if necessary (where applicable)
Service Interval Indicator / Oil Service Indicator or Intelligent Oil Life Monitor (IOLM) Reset after Oil change on all vehicles equipped with IOLM irrespective of whether cluster messaging is displayed
Seat belts, buckles and stalks Fully release webbing from retractor, check the webbing for damages, buckle up and unbuckle tongue, observe functionality
Odour filter Renew
Outside Vehicle
Hood latch/safety catch & hinges + Check operation/grease
Under Hood
Wiring, pipes, hoses, oil and fuel feed lines Check for routing, damage, chafing and leaks
Engine, vacuum pump, heater and radiator Check for damage and leaks
Coolant Check anti-freeze concentration: 1pix.gif °C
Coolant expansion tank and washer reservoirs Check/top up fluid levels as necessary - in case of abnormal fluid loss, a separate order is required to investigate and rectify
Battery terminals Clean, if necessary/grease
Under Vehicle
Engine Drain oil and renew oil filter (use torque 15 Nm)
Steering, suspension linkages, ball joints, sideshaft joints, gaiters Check for damage, wear, security and rubber deterioration
Engine, transmission, rear axle Check for damage and leaks
Pipes, hoses, wiring, oil and fuel feed lines, exhaust Check for routing, damage, chafing and leaks
Underbody + Check condition of PVC coating
Tyres Check wear and condition, especially at tyre wall, note tread depth
RF 1pix.gif mm, LF 1pix.gif mm, LR 1pix.gif mm, RR 1pix.gif mm
Brake system + With wheels off, check brake pads, discs, linings for wear and check brake cylinders for condition: check rubber components for deterioration.
Outside Vehicle
Engine Refill engine oil
Tyres Adjust pressure
Instant mobility system Check best before date on tire sealant - if applicable
Spare wheel Adjust pressure, check wear - condition (note tread depth)
1pix.gif mm
Tire pressure monitoring system Adjust tyre pressures, reset - if applicable
Luggage compartment lamp + Check operation - if applicable
Wheel nuts Tighten to correct torque and check for correct type. Check for rim damage (use torque 135 Nm)
Wheel covers Check for damages, especially at retainer system
Service record and MicronAir Filter reminder stickers Update vehicle service record (Service book/Digital Service Record (DSR) and affix stickers to driver side B pillar)
Service Activated Roadside Assistance
Ford Roadside Assistance Activate 'Ford Roadside Assistance' registration - if applicable (participating dealers only)
Extended Period Maintenance
Brake system Every 2 years - Renew brake fluid (LTS 12 154 4) Notice: Vehicles with ABS system, and specially Vehicles with Electronic Brake Booster (EBB) always require FDRS to be used for brake fluid change/brake bleeding (LTS 29 099 1). Bleeding the system without FDRS will result in braking or EBB failures. See FordPTS Brake Section D&O and General procedures for more details
L
Engine cooling system Every 10 years - Drain, flush and refill with purple Super Plus(LTS 24 122 4)
L
Oil Pump Belt Every 144 000 miles/10 years - Renew (LTS 21 716 5)
L
Auxiliary drive belts Every 144 000 miles/10 years - Renew (LTS 21 567 5)
L
Front end auxiliary drive belt & water pump belt Every 144 000 miles/10 years - Renew - FEAD Belt aligned to Water Pump Belt so perform combined service - more often under severe duty conditions (LTS 21 567 5)
L
Visual body & paint check Every 12 or 24 months depending on vehicle type and build year/registration date. Carry out during operations marked (+) above, see detailed Check Sheet - if applicable (LTS 54 555 1 +)
L
Extra Services and Additional Offers * (optional - upon customer request / charged separately)
AC maintenance package Air Conditioning (A.C.) system check. Apply A.C. cleaner (recommended FINIS 2395156) to air distribution system. (LTS 54 552 4)
L
MicronAir Protect Filter (required to be changed in 12 months or 18,000 miles whichever occurs first) Upgrade to safe protection against various virus types.
+ Visual body and paint check should be carried out during these operations on vehicles built from 03/2002 onwards - see detailed Check Sheet if applicable.
Separate labour charge dependant on market regulations.
As mentioned in the schedule above, at Ford you get 12 months extension to roadside assistance which may be of value. Not all dealers participate, so check before booking:
Ford Service Assistance
If you take your Ford to be serviced at a participating Ford Dealer you will receive UK and European Roadside Assistance valid from the date of service for 12 months, or until the next service is due, whichever comes first. Plus expert service from a Ford trained technician using specialist Ford tools and quality Ford parts.
Ford Service Assistance is available when your vehicle has a Scheduled service, Convenience Check or Interim Service.
Service Schedule
Model Focus 2019
Repair/Order No
Reg. No.
Reg. Date
Radio Code
Mileage ml
Inside Vehicle
Odour filter Renew
Outside Vehicle
Under Hood
Under Vehicle
Outside Vehicle
1pix.gif mm
L
L
L
L
L
L
L
I'm very grateful to you for providing what's done/needs to be done and for providing the labour items too. I will check them closely and also print it all.
Thank you too for advising me what Fords provide. I'm pretty sure my son already has roadside assistance, within his car insurance . I guess that's why Fords charge a premium price too. You get what you pay for, they say. I understand that the 2 year service even if the mileage hasn't been done is a scheduled service. I see that quite a few garages ( non Ford) say  "full service" or "major service" ; the prices are different.
