ACC steering wheel buttons
Last week I used forscan to enable ACC and it works great! I've now ordered the buttons that have the distance select option (H1BT-9E740-DB) has anyone fitted these before? I'm struggling to find any information on how to fit them.
Any help is appreciated 👍
Have a look at FORScan info.
https://forscan.org/forum/viewtopic.php?p=63283
Thank you very much! It seems it's easier than I thought.
If I don't have to disconnect the wires from the airbag should I still disconnect the battery?
Personally I would disconnect the negative battery lead while working.
You have to configure the buttons using Forscan too
Is it just the case of changing the product number in the steering module?
Yes, change the part number
