Low Pressure A/C Port Location - MK3 Focus 2012 2.0 TDCi
Hi all, I cannot for the life of me find the low pressure port to regas the AC on my car, I’ve tried to look up the ports location online with videos of others performing the regas and it seems to be in one of two places but isn’t on mine? I tried finding a workshop manual for the car to find a diagram but couldn’t find the right manual for this engine / config
I’ve Found what is think is the correct hose along the back behind the engine but cannot feel or see the dust cap for the port
Hoping someone can help located - I’ve attached pictures and circled where I’ve looked, as title is a 2012 MK3 pre facelift, 2.0 TDCi Titanium X
If you take your engine cover off it is behind your engine and lower than the top of your cover.
22 hours ago, unofix said:
Thank you both for your answers, I can see from that diagram and chart that the 19D702 is the cap for the low pressure port, the angled valve on the right is indeed behind my engine slightly lower just as you described and pictured however I couldn't see or feel the protruding part with the cap on it at all (circled the parts I mean in attachment), at this point I will have to go back and have another look tomorrow when it is daylight - It must be there!
Is this the low pressure port? Looks like a pressure switch to me. But can't find anything else on the pipes. Same car and same engine.
nope, its a silver pipe with a big black dust cover on the refill port.
Exactly where I was at with this, what you’ve pictured is what I have on mine - but it’s not the low pressure port - whatever that is seems to be close to where it should be, bit that isn’t it 😞
Haven’t came back to this since my post but going to give it another go this weekend
Update: finally found the port, its below the oil refill cap - move a hose to the side and you'll see the port, pictures & video attached
Re-gas'd successfully, may have overfilled it but thats a separate issue to tackle, gauge was reading low 12psi before adding refrigerant, got it up to 30 although I then kept trying to add more and it wouldn't go above 30....
Either way its now blowing ice cold air so thats a start!
Thanks for all replies and help with this - hopefully these pictures and video help anyone else that gets stuck with this!
