2014 Ford Focus Zetec S Advice
Hello i am back to where i always get help from 🙂
So 20th Dec a car rolls down the street and bumps into my parked car damage to the car cracked the front bumper and smashed the slam plate & lower right grill.
Advice does the lower splitter fit any bumpers from 2011 - 2014, if no which ones ? i am sure i read somewhere they do but i am not 100% sure.
Now the rear bumper i have No clue what you call this part of the bumper, its the part between the lower black skirt and the upper bumper, it holds the 2 reflectors one each side, whats it called ?
Advice does the lower Black skirt come off.
Looking for Red front Bumper bar Slam Plate, grills if not with bumper and rear bumper unless i can find that bit for the middle, depending on the price i may get other colour parts.
And the claim i would have made due to age of car and the miles it would have been wrote off, due to cost. so i need your help !
I think the best thing to do is post some photos here of the parts you are looking for. There are about 10 versions/combinations of the rear bumper and a similar number of options for the front parts. If your hoping to get the parts in the same colour as your car then we need to know the exact paint name/code, although I doubt you will be lucky enough to get the right parts in the right colour.
Ford call the lower coloured part of the rear bumper a 'skirt' and the black part a 'deflector'.
It does come off.  Just clipped together using plastic tabs.  You will also need the tow eye cover if that's missing.
You may find the crash bar has been bent behind the rear bumper.  If so, that is a structural part which will need replacing also.
The front bumper 'extension' does fit all standard bumpers on the Mk3 pre-facelift.  It does not fit ST bumpers.
With that type of front end impact I would also want to check the air con condenser, the active grill shutter and the intercooler (where applicable) for any signs of damage.
The colour name is Race Red, previously known as Colorado Red.
