Fiesta 2008 Mk6 1.25 judder / miss fire
Have a 2008 1.25 MK6 Fiesta it had a miss fire cause a few exhaust pops/bangs so changed plugs/leads/coil solved most of the problem but when car is very cold and started it runs fine around 1100rpm ish as it warms up and rpm drops the problem occurs its like a miss fire every couple seconds exhaust note change no pops tho hand under load sometime it will happen but mainly when warm at tick over, check cleaned the pcv valve but looked ok, removed throttle body cleaned and also cleaned carbon tracks inside no difference, so running out of ideas what to check next.
Make sure the engine earth isn't loose or heavily corroded
Check MAF sensor is clean and air filter is clean and dry.
After that it sounds mechanical (head gasket or valves)
Ok Thanks for you reply
