Electrical errors galore....
I’m new to the forum so bear with me. I’m stuck with a car with the immobilizer engaged amongst other electrical issue and I have no idea where to start. I have it booked in with a specialist but I’d like to at least try and rule out a few things before it goes in to save a few quid. You will see why below....
It started randomly with an engine management light coming on after working perfectly fine, then when I parked up the car locked itself in park, then after getting it home the immobilizer kicked in and wouldn’t start.
Any ideas on what the failure could be? Any recommendations on where to start? Either the ABS module or the instrument cluster have been mentioned as potential causes but I'm not sure if there is any basis for the suggestions.
A friend read the error codes and here is what popped up. Many are duplicated though each of the modules:
Engine
P0504-71 - Brake switch actuator A/B stuck
P2038-00 - Throttle pedal position sensor D voltage correlation
U0415-86 - ABS control module invalid data received
U0418-08 - Brake system control module invalid data received
U0129-00 - lost communication Brake system control module
P2121-00 - Throttle pedal position sensor D circuit range
U0129-87 - lost communication Brake system control module - missing message
Transmission
U0121-00 - lost communication ABS control module
Body Control Module
C1120-15 - Reversing lamp short to battery
B10A2-02 - Crash input signal failure
B10A2-15 - Crash input circuit short to battery
B10AE-13 - Positive temp coefficient heater - open circuit
U0452-00 - invalid data received restraint control module
U0452-62 - invalid data received restraint control module - signal compare failure
U3000-04 - control module system internal failure
Electronic Power Steering
Tire pressure monitoring system
Electronic air temp control
B105A-14 - Cabin temp sensor fan - short circuit to ground
B1A69-14 - humidity sensor circuit - circuit short to ground
Instrument Panel
U0151-00 - lost communication with restraint control unit
U0422-68 - Invalid data received body control module - Event info
U0415-68 - Invalid data received body control module - Event info
Parking aid
U0422-00 - invalid data received body control module
Immobilizer
OBDII
U0415 - Invalid data received ABS control module
Could be faulty cluster solders
Wasn't aware if they occurred in such a late model as a 2013 year. However, just in case...
Starting with the basic of the basics. What it the battery terminal voltage measured with a multimeter one hour after the car is parked ?
If it is more than 12.2V then you need to remove and inspect the Body Control Module (BCM). Look for signs of water ingress and/or greenish corrosion of the connectors and plugs.
Thanks.
Thanks. I'll give it a shot and see if it makes any difference
Thanks. These will be helpful! Seems simple enough to remove and the guy on ebay seems to have plenty of experience with these clusters.
The car has been sat for a month over Christmas so I'm unable to check. I believe the BCM is behind the glovebox like the C-max?
Unless your battery is very low, of course
Unless you own a Toyota, it's unwise to neglect a Ford for this length of time as the battery won't cope. (Mums 22 year old Toyota Yaris was left abandoned 4 months over lockdown, and started 1st twist of the key)
The BCM looks to be in a decent state. No water ingress or corrosion.
The battery is still in a decent state. Its been fully charged today
The soldering looks fine and nothing seems to be loose
I'm curious what your definition of, 'a decent state' is?
75% charged when it was connected to the charger.
