Intermittent TPMS error on Focus ST2
Has anyone ever experienced an issue like above. I reset the TPMS and it’s fine for around 30 miles then flashes up as if I have a flat tyre flashing on the dash and says service required. After a mile or do the display stops flashing and can be reset.
If you're still on the original factory fitted tyre pressure sensors then the batteries will be going flat. The TPMS sensors are only expected to last 7 to 10 years depending on mileage. In this cold weather any batteries nearing the end of life will cause intermittent tyre pressure warnings.
