2019 Focus rear washer not working
In the past few months the rear washer was a trickle of water, and now it's stopped altogether.  When I put it on I can hear the motor whirring but nothing comes out at the back.  After a while the car interior does smell of washer fluid, so I think there's a leak somewhere.
Bearing in mind I get most of the work done at a local Ford garage is it worth me checking anything?  I have checked that the nozzle is clear at the rear window..
If you're feeling confident try removing the high level brake light hopefully the pipe has just come off.
Beyond what gds1972 said, you will have to drop the headliner to see if there is a split pipe
