unlock drivers door only 2017 - how
do I enable ) disable this, will be using it as a quick fix until I can get boot issue sorted
In cluster settings or FORScan, can't remember, sorry
Reprogramming the Unlocking Function
Press and hold the unlock and lock buttons on the remote control simultaneously for at least four seconds with the ignition off. The direction indicators flash twice to confirm the change.
To return to the original unlocking function, repeat the process.
Does that still work on MK3?
Should do.
cheers guys, the fob resolution worked, boot still opening when pressing the open door button , ah well another quick fix ruled out
It just needs the boot handle replaced. Under £22 on eBay and 15 minutes to fit.
Without reverse camera: https://www.ebay.co.uk/itm/115023597410
With reverse camera: https://www.ebay.co.uk/itm/354489964352
tried that pal, no difference at all
Then it would seem you have the infamous problem of water ingress to the BCM 🙁
that does not sound good
Disconnect the battery and remove the BCM (Fusebox under glovebox) inspect the terminal pins and the visible board for water damage, it will show as green fur.
If this is present then the BCM is going down
sounds expensive !!!
right , apologies for all the questions, but I've it booked into a local ford dealer to have it plugged into their machine  100 quid straight away 😕
what am I looking at cost wise if it is the BCM
and is there any possible way it's something else
keeping in mind my mechanical knowledge is very limited
If it is the BCM, You're better off having yours repaired or buying a good used one.
The Mk3 BCM alone costs over £800 from Ford.
https://www.ebay.co.uk/itm/393396372363?
