MK3.5 focus wingmirror frame holder replacement?
The clips that hold my wingmirror cover in place have snapped . So I'm needing to replace the wingmirror fascia .
How easy is this to replace ?  It's looking as if the whole wingmirror needs to be taken off ? . I'm also struggling to find where to buy from as they're all from sites I've never used before
It's my passenger side mirror , I have a mk3.5focus .
This is what I'm needing below
https://www.fruugo.co.uk/side-wing-mirror-frame-holder-for-focus-mk3-mk2-2008-2018-outer-glass-surround-housing-trim-replace/p-217227684-463090615?language=en&ac=croud&asc=pmax&gad_source=1&gclid=CjwKCAiArLyuBhA7EiwA-qo80IhvvNN6vEqKson4zRvps_38otP8g0UKzO9Tg3nXM-jdwiEX8xXBuRoCp1wQAvD_BwE
Hi Becca and welcome to the forum.
From what I can see, in the link you provided, I don't think the whole mirror assembly needs to come off.
Mirror shrouds and the mirror itself are snapped on. Basically take the glass out. It's probably held in by 4 pop brackets. Then the inners will be visible and the shroud should snap off with some pressure.
Have you looked on YouTube for how to remove a door mirror for your car? If not I recommend you do and go from there.
