2007 Ford S-Max Diesel, Cannot find fuel pump
Hello!
Recently stumbled upon an error DTC #01 90BD13 which indicates that the fuel level sensor is broken.
I have been surfing through the internet to find the exact location of the 2007 Ford S-Max Fuel pump and only found similar cars such as Galaxy.
All I know that the fuel level sensor is located inside the fuel pump. As looking through the tutorials of every fords fuel pump I noticed that it's located under the back seats.
My father told me that it's not there and we also have different seats which you actually have to take off by ***** the hell out of them amd removing them from the car.
Does anyone have an idea where it is located?
Thank you!
On 2/24/2024 at 3:48 PM, WillyViitla said:
Hello!
Thank you!
that error code relates to an error in your instrument cluster nothing more, ideally needs plugged in via obdII port and proper codes reading. on diesels the fuel pump is on the engine not in the tank. is your fuel level showing correctly?
