Car keeps draining battery
Hi there I have a ford s max 2012 I have taken the car to garage because the battery keeps going dead it’s had a new battery and everything has been checked on the car but still keeps going flat
47 minutes ago, Catton03 said:
... everything has been checked on the car but still keeps going flat
With respect, if 'everything' has been checked, you would have found the fault. Can you let us know what diagnosis have been carried out? Do you have a BluTooth module operating? This is a common drain as when it goes faulty, it carries out a continuous drain on car even when switched off. Otherwise, your next port of call is to carry out a proper diagnostic using ForScan, a dedicated Ford software as a free downloadable on Windows with a proper cable to see what fault codes are showing...
The very fact that you've already taken the car to a 'garage', I would suggest if you don't feel confident doing diagnostics yourself, you leave it to a proper auto electrician to diagnose the  drain.
