Showing Temperature
Good day.
Is there a focus mk3 sync 3 or 3.4 to show cabin temperature degrees?
The outside temperature value is not always right it shows one or two degrees higher or lower, usually higher.
It doesn't really matter where it displays the data, the data is taken from the sensor in the LH door mirror head
Is there a way a sensor also for cabin (inside) temperature ?
Only climate control equipped cars have interior temp sensor
focus mk3 has that?
how can someone find out?
If you have a Lidl near you, every few months they sell a temperature gauge for about €10, it will display cabin temperature as well as outside (if you hook up the external sensor)
Is there a stock installed sensor in this model?
I think Dave already answered this question.
Unless the car is factory fitted with full climate control it does not have a temperature sensor fitted in the cabin.
The only temperature sensor fitted is the one fitted in the left hand door mirror and it only measures outside temperature.
