Ford focus mk2 1.6
Good morning guys,
Hoping to pick someone's brains if possible, had no problems with car, starts every time, yesterday was no different though then noticed the red cog with exclamation mark, literally pulled over to look at phone turned engine off, then restarted car, started fine light had gone,car drove fine no issues, drove home, each time I restarted car the light had gone, transmission fluids etc all checked. Partner decided to spray leads (wd40) and restarted car, as we've had loads of rain, he said all lights lit up and car started but no power under gas but immobiliser flashing. Haven't driven it but starts fine again now, partner disconnected battery for half hour,as per advice on another page. Just wondering if anyone else had the same problems? Or advice please, thanks 😊
Get the codes read (not service mode in cluster) using FORScan
If you see lots of  "Lost Communications with..........." codes
And, more importantly "THEFT detected" then I suspect the cluster is at fault, send it away for repair
