Ford galaxy 2004 doors wont lock and turn signal flash
Hi i have ford galaxy 2004 and doors stoped locking and turn lights flash 4 times when i use remote i have to close all doors from inside and drivers door with key how to fix please help
Fuse 75 (30A) in the bottom relay panel of the central junction box would be a good place to start.
The vehicle thinks that one of the doors is not closed. Have you any warning on the instrument cluster showing "Door Ajar" ?
No there is no warning lights
i'm going to try
Then you will need to use FORScan and check for any DTC's which is inhibiting the door locks.
FORScan: https://www.forscan.org/download.html
vLinker FS cable: https://www.amazon.co.uk/Vgate-vLinker-Adapter-FORScan-MS-CAN/dp/B0952P4MLP
