Auto locks
hi
I have a Ford focus mk3.5. The auto lock is off & I’ve tried the standard press the unlock button 3 times etc to programme it. However it doesn’t work whatsoever, do they need to be coded in, rather than programmed with the lock buttons? Thanks
Auto lock, has to be enabled using FORScan on UK vehicles
It’s a polish car. Do you know if that’s the same?
Yes very probably the same. Use FORScan to enable auto locking and also add the option to the IC menu.
Thank you
