Sync 3 Clock Resetting
Hi all!
Having quite an annoying problem with my clock on the Sync 3.4 system.
Whenever I set the time, it instantly resets to a random time far out what I want.
I've disabled the automatic mode, I've tried to reset to GPS time, I've updated the Sync system, done multiple master resets, but no solution!
The most annoying part of this is that I can't connect my android auto as the clocks don't match!
Here's a video of it: https://youtube.com/shorts/-Vj8S9z4-48?si=sj6NMzXQAoyO0ToN
Please can anyone help.
You've got a 2018 car, so I'm guessing you used cyanlabs to unofficially upgrade from Sync 3.0?
This is one of the known bugs when doing that, you might have better luck on their forum asking how to fix it, or an older version that doesn't have the bug.
  • 1 year later...
Hi guys...i'm having a similar issue...
I set the clock...but wen i select "HOME" ...the clock disapears and shows  --:-- 😞
Sync 3.4 Build 23188
I've read on CyanLabs that this build (23188) has this issue and users suggested to downgrade to 3.4.21265 ...but still the issue persists 😞
After updating to
3.4 Build 23188, i've JailBrake'd it so i can set my own backgrounds ...could this be the problem ?
