rear jet wash
i have 2018 galaxy rear jet no water but can hear pump working
Usual problem is a stuck/blocked non-return valve. Located in the head lining near the tailgate.
paper clip down the jet see if it needs clearing, any wet bits internally ?
BRILLIANT SOLVED THE PROBLEM NONE RETURN VALVE IN THE RUBBER GAITER BETWEEN BOOT LID AND BODY RIGHT HAND SIDE ONE TOOK OFF AND DRILLED OUT .REFITTED IT NOW PERFECT THANK YOU FOR YOUR HELP
