Focus Titanium infotech screen
Can anyone tell me how to adjust the brightness on the screen. I touched something on the way home in the dark and it went full glare which is dangerously distracting. Cannot for the life of me find the button I pressed to get it back to normal.
You might have selected constant "day" mode in the display settings
Well it was on full glare night mode which is pretty scary when you are completely blinded!
turn down the brightness
That’s the point. I cannot find any control to turn down brightness only on and off.
Screen brightness is adjusted using the instrument cluster illumination control next to the headlight switch.
Screen brightness only adjusts the instrument panel, not the infotech display
Is it adjusted via the "settings" menu then "display" on the Sync screen?
Can't check at the mo as the Ford website "download a manual " feature seems unable to identify ANY vehicles, including mine - anyone else found that today?
Edit:seems to be working now! -
Display
Menu Icon  You can adjust the display using the touchscreen or the voice button on the steering wheel controls.
To make adjustments using the touchscreen, select:
Menu Item   Action and Description
Settings
Press the settings icon.
Display
Then select from the following:
Mode
Allows you to switch the display off. It also allows you to set the screen to a certain brightness or have the system automatically change based on the outside light level.   If you also select:
Auto
These features will allow you to adjust the dimming of your screen.
Night
Edit Wallpaper
Allows you to display the default photo or upload your own.
Auto Dim
When set to On, lets you use the automatic dimming feature.   When set to Off you are able to adjust the brightness of the screen.
Brightness
Make the screen display brighter or dimmer.
Auto Dim Manual Offset
Allows you to adjust screen dimming as the outside lighting conditions change from day to night.
Voice Activation - Speak
To make adjustments using the voice button, press the button and when prompted, say:
Voice command
Display Settings
