Ford Transit Custom 2017
Hi there, I'm looking at replacing my FTC battery and wondered if anyone had any suggestions for alternative?
Are original ford batteries (AGM I believe) worth the price tag? Are there better alternatives?
I'm happy to pay I just want to make sure I get a decent battery.
Appreciate any response
Zee
Ford don't actually make batteries. For the last few years they have been made for Ford by Varta. If next week Ford get a better deal from another manufacture then they will change supplier.
Your vehicles charging system will be programmed to either support an EFB battery or an AGM battery. You shouldn't change the battery type as the vehicles charging algorithm will not make best use of the battery, and could even shorten the life of it due to repeated over or under charging.
Check carefully which type of battery is fitted (or is meant to be fitted) to your vehicle and replace it with the same type. The actual brand type of the battery is a matter of personal choice. Many on the forum (including myself) prefer to use Yuasa.
You can check your battery type and choices here: https://www.tayna.co.uk/
Thanks mate, appreciate the timely and informed response.
