focus mk4 automatic trasmission problem clutch
Hello , i bought a used ford 1.5 tdci 8automatic  and i am having a problem with a  clutch when  change gears. I dont have any codes when i went to ford dealer and they could not find anything. The problem is not all the time but when the clutch starts it impact when i shift to all gears . I find a video to youtube with the exact same problem . I would like your opinion . thank you. sorry for my english is not my language.
  • 1 month later...
Someone told me that i need a tcm reset.I tried but i couldnt do it. Can someone please tell me the right steps. thank you
  • 3 weeks later...
I can't tell what it's doing wrong from that video
If mileage is over 40,000 then consider changing the fluid
If you're getting torque converter shudder then add 2x tubes of shudder fixx to fluid
Ensure battery voltage is good, MK4s suffer with poor battery voltage and transmission solenoids rely on good voltage
Thank you very much for replying.
bought the car used and the problem started after 3 month use.
I don't  make long distance with the  car and the problem doesn't appear but when i make long after a while that problem appear.
I take the car to ford twice and told me that is fine and they dont anything strange.when i ask ford to change transmission fluid they told me that i dont need and they dont see any code problem .
I will start with changing battery because the starstop have stop working and i  will change transmission fluid because the car is used and it have 99000 miles and i dont know if they have change fluid before.
99,000 miles, the fluid is old now, that will cause shift issues, definitely change the fluid and add shudder fixx when you change, there's no filter, just drain and refill, then run car for 10 minutes (ensuring it goes through every gear) then check level and top up.
Ford won't recommend changing the fluid as, they say, it's sealed for life
Definitely change the battery
  • 1 month later...
Thanks you very much.I already change the battery and now i will change the transmission  fluid.Do you have a specific shudder fixx to suggest and how much i need ?
Lubeguard shudder fixx, put in two tube whilst on idle then run the car through the gears to get it round the system.
After you've changed the fluid of course
  • 1 year later...
thank you very much you save me.I change the fluid and i add 2 shudder fixx.Now the problem disapear and i made a big journey with no problem.
now i will change the fluid after 30000kilometers.
What is your opinion of some mechanics shops that wash the transmission ?
It's expensive as you have to use/waste so much fluid.
Just drain and replace the fluid often
