Ford fiesta error code & spanner light
Hi I have a spanner light keep coming on my car. The fault code first showed as MAF sensor failure so replaced that and it’s cleared and now I’ve got fault code p007d. It runs fine until the spanner light comes on then the car is laggy, I’ve had it serviced but can’t keep chucking money at sensors if it’s a bigger problem. When I turn the engine off the spanner goes off then comes back on again 10 mins later. Any help is appreciated 🙂
Your 2015 Ecoboost 1.0 will be an even bigger problem in less than 12 months when you have to change the wet belts
I’ve got that booked in for next month as I only bought the car about 6 weeks ago and I wanted it done for piece of mind 🙂
Fully charge the battery then clear the DTCs and see if it comes back
@DaveT70 still having this problem and done everything I can think of, changed sensors, charged battery, cleared faults etc but still happening?
