Radio Troubles
I've got an issue with my radio navigation system where it will not switch on.
Until this morning, I didn't have any warning of any issues.  It just refuses to switch on when you press the on/off knob.
I've checked the 15A fuse in the back of the unit, F108 7.5A and F112 15A and they all seem ok.
I suspect it's finally given up but wanted to check whether anyone else has any useful ideas to try.
In case I end up having to replace it, does anyone know what unit this is?
It's from a 59 plate Focus Diesel Titanium.
This looks like what you'll need as a direct replacement...
The final thing to try is disconnect the battery main negative lead and leave it off for 20 minutes. That will force a reboot of all modules when you reconnect it.
This looks like a better deal 😉 The man above has too much money 🤣
Ok, thanks guys.  I'll give that a go 😁
