Turn off interior courtesy lights ??
Does anyone know of a way to keep the courtesy lights off when any of the doors or sliding doors are opened ? We have started using the van for camping and when sleeping we would prefer to have the lights permanently off as we settle out son to sleep before we go in,
Yes. You need to fit a switch in the wire from connector C311 pin 32 (Grey wire with Violet tracer)
Oh amazing , that would be an ideal project, do you have any information on the route of that cable on where to position switch
The route of the cable is exactly as per the drawing above. You will find C311 on the side of the transmission tunnel towards the clutch pedal side.
You can locate a switch anywhere that is convenient. I would probably fit it on the centre console and charge you £100 😉
