MK3 Suspension Rattle/Squeak
Evening all,
Quick one - are there any 'common' components on the front suspension of a MK3 Focus to need replacing around 10 years/70k miles?
I've had for a little while now a clunking over rough ground, normally worse when turning right. Convinced it was going to be worn droplinks, I replaced them - but the noise is still there. I think it's front left biased but can't honestly pinpoint it.
I'm now getting a squeak/squeal (sounds like rubber rubbing against metal) when turning the steering wheel from the front left (passenger) suspension assembly - worse when there is someone in the front passenger seat.
I don't want to start replacing components willy-nilly so will probably end up booking it in somewhere for a proper checkover but would be nice to know if this was something 'common' at around this sort of age/miles...
I've had it up in the air today and couldn't see any obvious signs of worn bushes, couldn't locate any play (apart from a very slight 1mm rotation in the spring) - so I'm leaning towards perhaps the strut top mounts?
Cheers,
Nick
