Forscan and Vgate vLinker FS OBD2 USB Adapter
Hi , bought obd cable recomended by forscan as i wonted to see what error code showing my ford galaxy (airbag light on dash). it is conecting reading but only 2 module obd2 and PCM
The question is should i see more module liek srs airbg and others? or i do somthing wrong. Ford galaxy 2004 2.3 .
on your model if details correct you need the modified ELM327 cable, seems to work best. Check all connections associated with airbags, disconnect the battery negative before checking so they dont accidentaly go off.
