ABS update
Checked  n/s/f abs cable and  sensor with a multi meter . ohms and continuity also checked the cable with a test lamp  all seem ok, the fault code  on forscan  COO31  31  C8. when I removed the sensor all I could see was basically rust with like two raised outer edges. I reset everything , then basically drive 20ft and fault reappear. Any help would be appreciated.
firstly i would replace the sensor itself, a second hand one just in case. after that i would be looking at the wheel bearing, as that is what the sensor reads moving
I replaced the sensor , will check the wheel bearing. thanks
